Here is a partial list of tools available, I will add few more in couple of days.
8790776 Puller, inner driver housing
8790511 Press used as is to press out pinion shaft on 4 speed boxes, or with 4 100mm spacers on 5 speed boxes.
Kent-moore 499207400-A Subaru camshaft wrench
KM622-A Tensioner holding wrench
8392961 wrench for crank shaft pulley bolt, saab-900
8394033 lever arm to hold pressure plate fingers, clutch
8996605 brake measur tool
8395246 valve tool
8996613 strut socket
8996407 power steering assembly sleeve
8996670 shock absorber wrench
8996662 strut spring nut wrench
8996654 driveshaft tool for 9-3
8393472
8393993 Flywheel Locking Attachment
Blue Point telescoping magnetic pick-up tool PT-28D
8392987 FLYWHEEL LOCK
8791915
8790963
8395436
8396277
8394066
km-535
8790081
km 28099PA100
8791113
8396194
8393993 x3
8792442 Lifting Cable
8791048 REAR CLUTCH TOOL
8792616 driveshafts removal tool for 9-5
8790107
8792590
8392540 Rear Main Seal Installer
8394884 Rear Main Seal Installer
8996464
8790875
8395254
8791980
8791816 TORQUE CONVERTER PLIERS
KM460-2 B
8394462 Fuel pump removal tool for any 90-98 900, 90-98 9000, 9-3 99-02 & 03 all, 9-5 99-05 all.
8791444 crowfoot
8792327 9-3 clutch tool
8394140 FILL CAP ADAPTER
8394934 or KM 635-2 Crankshaft Seal Installer
879024
8395287
8396095
8790552 Stack height tool. 195.0mm - 195.1mm if using a depth tool.
8791964
8792277
8392128 x2
8792574
8996043
8790107
8394876
8394942 or KM-693
8394959 or KM-422
8790503 Catch, reverse wheel. Locks transmission to remove nut.
8790909 x3 distance screw for pinion puller 58
8790974
8791345
8790370
8292799 x2
8292492 x3
8395246 valve tool
8393472
8791915
8790963
8395436
8396277
8394066
km-535
8790081
km 28099PA100
8791113
8396194
8393993 x3
8790107
8792590
8996464
8790875
8395254
8791980
KM460-2 B
8791444 crowfoot
879024
8395287
8396095
8791964
8792277
8392128 x2
8792574
8996043
8790107
8394876
8394942 or KM-693
8394959 or KM-422
8790974
8791345
8790370
8292799 x2
8292492 x3
