Instrument cluster removal.
1) Using a small screwdriver through the air vent grilles, release the hooks and remove the centre - and left hand air vents from each side of the instument panel.
2) Undo the 2 Torx screws and pull the infotainment control panel from place. Disconnect the wiring plug as the panel is withdrawn.
3) Reach through the aperture, squeeze the retaining clips together, and starting at the top, push the SID control panel from the facia. Disconnect the wiring plug as the panel is withdrawn.
4) Undo the 7 screws and pull the instument panel surround trim from place. Where applicable disconnect the wiring plugs as the trim is removed.
5) Undo the instrument panel mounting screws.
6) Withdraw the instument panel far enough to disconnect the wiring.
7) Refitting is a reversal of removal.
