Recomendations on how to fix rust on frame
2 reading
2.1K views 4 replies 5 participants last post by  mnztr
#1 ·
Hello all. I am new to this site. This is my first thread so please go easy.
I am looking for constructive help on how to fix rust on the front sub frames of my car and my wifes. We have no garage so I will have to wait until spring for this project, but just curious about sugestions. I was under my car changing my oil and noticed more rust than there should be for a three year old car. I am hoping to keep our cars for a long time but that will only happen if I can keep them in good shape.
My plan is to sand down rust spots that I can, then paint those areas with self etching primer. Next I was going to try and paint the whole sub frame or at least what I could (along with the A arms) with 3M undercoating.Of course I would tape off and cover everything I do not want to get coated.
What is the product that turns rust into black metal with a chemical reaction?
What say you?
Thanks in advance.
#2 ·
As long as none of it is truly "structural", that plan sounds like a good one. If you can prep everything well enough, POR15 is all the rage these days for protecting metal surfaces.
As for the stuff that converts rust, it is called Rust Reformer and is available in a normal paint can or in a spray can.
On another note, I still find it slightly odd that Saab decided to use a steel subframe for these cars. All of the new-ish Volvos have had aluminum subframes for at least 15 years now.
#4 ·
On my 1962 Triumph TR4 frame I have cleaned out as much rust as I could using abrasive disks or wire wheels - no substitute for physically removing it. However, there is always some you can't get too, so I then used Eastwood Rust Converter followed by their Rust Encapsulator. Like POR15 this is used by classic car restorers, but unlike POR15 it is not as fussy about needing spotlessly clean surfaces before application. On a subframe, this could be followed by Eastwood Chassis Black. I do not work for Eastwood or have any financial interest in them, but this approach has worked well for me. http://www.eastwood.com/rust-solutions/treatment.html
