9-5 openSID Engine Mode page exit??
1.5K views 1 reply 2 participants last post by  karajaula
#1 ·
Hello All.
Searching for Pdif in openSID mode 6, it turns out this ECU has the Disc, Knk1, etc. etc Mis1 etc. etc. selection.
Can anyone tell me what I must have done to get into the Engine Mode E N S screen, and equally as important, how to leave it? I've read of three methods, none of which work on my stage 1 2004 Aero.
Also, what exactly are the knock and Misfire counts? Totals for the previous cycle?
Interesting to see that I get a SID message when engaging cruise, disengaging, changing the ref speed, and when the cruise is switched off and I press the engage switch, SID shows Max Speed for that cycle.
Does it have any other secrets which only appear when in the Engine Mode E N S page?
Many Thanks - Doug
#2 ·
You should search the Disp symbol, press set and change to 1. After that every time you press + and -, it will display engine modes. This screen disappears after a few seconds. To return to normal SID screen (not openSID) you should press also brake pedal in addition to + and -, otherwise, it will show engine modes screen again.
Not all bins have Disp enabled, if you can flash you ECU, you can add it to openSID symbols with t7suite
