Hello, I have a 1999 Saab 9-3 manual hatchback and I’ve recently been having a weird issue. When accelerating into first, after letting off the gas, the revs stay constant instead of dropping back down (the car is accelerating for a few seconds after letting off the gas). It continues to do this when shifting into different gears. Also, when shifting into neutral, the revs skyrocket to 2000-4000rpm for a few seconds until the eventually fall down. I have replaced the throttle position sensor and cleaned the throttle body. I ordered a new idle air control valve, but that is the last thing that I can think to replace. I also checked all vacuum lines and there are no leaks to my knowledge. Below are two different video links of the issue. In the video of the throttle body itself, I tapped the accelerator to get it up to 2000rpm and immediately let off. The mechanism appears to get "stuck" for a few seconds before closing completely. However, when operating the mechanism by hand, it is smooth and does not catch at any point.
